Yeni başlık gönder Bu başlık kilitlenmiştir mesajlarınızı düzenleyemez veya cevap gönderemezsiniz.  [ 1 mesaj ]
 Mesaj Gönderilme zamanı: Cmt Kas 23, 2013 1:38 pm
nsxr
1st Generation
Year '79-'82
Model N/A
ENGINE
Type Inline 4
Displacement 1751 cc
Horsepower@rpm (SAE net) MT / AT 72@4500 / 68@4500
Torque (lb.ft.) MT / AT 94@3000 / 94@2500
Compression Ratio 8.0:1
Valve Train SOHC 12-Valve
Fuel Induction System Venturi Carburetor
Ignition System Electronic
EPA Estimate (manual) ??
EPA Estimate (automatic) ??
DRIVE TRAIN
Type Front-Wheel Drive
Manual Transmission 5 Speed
Automatic Transmission 3 Speed
Final Drive Ratio (MT / AT) 3.875 / 4.214
BODY/SUSPENSION/CHASSIS
Body Type Unit Body
Suspension (front/rear) 4-Wheel Independent w/ MacPherson Strut
Stabilizer Bar (mm, front/rear) NA/NA
Steering Type Power-Assisted Rack and Pinion
Steering Wheel Turns, Lock-to-Lock 3.26
Turning Diameter, Curb-to-Curb (ft.) 33.5
Brakes Power-Assisted Front Disc / Rear Drum
Wheels 13" Steel
Tires 175 / 70 SR 13
EXTERIOR DIMENSIONS
Wheelbase (in.) 91.3
Length (in.) 161.4
Width (in.) 64.4
Height (in.) 51.0
Track (in., front / rear) 55.1 / 55.5
Ground Clearance (in.) 6.7
Curb Weight (lbs.) MT / AT 2130 / 2146
Coefficient of Drag (Cd) ??
INTERIOR DIMENSIONS
Headroom (in., front/rear) ??
Legroom (in., front/rear) ??
Shoulder Room (in., front/rear) ??
Hiproom (in., front/rear) ??
Cargo Volume (cu. ft.) ??
Interior Volume (cu. ft.) ??
CAPACITIES
Engine Oil with Filter (qt.) 4.2
Fuel (gal.) 13.2
Cooling System (qt.) 6.4
2nd Generation
Year '83-'87
Model S Si
ENGINE
Type Inline 4
Displacement 1829 cc 1955 cc
Horsepower@rpm (SAE net) 100@5500 110@5500
Torque (lb.ft.) 107@4000 114@4500
Compression Ratio 9.1:1 ??
Fuel Induction System Venturi Carburetor PGM-FI
EPA Estimate (manual) 24/32 25/30
EPA Estimate (automatic) 23/30 23/29
DRIVE TRAIN
Manual Transmission 5-Speed
Automatic Transmission 4-Speed w/Lock-Up
Final Drive Ratio (MT/AT) 4.071/3.875
Body Type Unit Body
Suspension (front/rear) Upper Wishbone, Lower Control Arm/MacPherson Strut
Stabilizer Bar (mm, front/rear) ?? yes/yes ??
Steering Type Variable-Assist Power Rack-and-Pinion
Steering Wheel Turns, Lock-to-Lock 2.84/3.25
Turning Diameter, Curb-to-Curb (ft.) 34.1
Brakes 4-Wheel Power-Assisted Disc
Wheels Steel Alloy
Tires (Spare) 185/70SR13 (T105/80D13)
EXTERIOR DIMENSIONS
Wheelbase (in.) 96.5
Length (in.) 169.1 172.0
Width (in.) 66.9
Height (in.) 48.6
Track (in., front/rear) 57.9/57.9
Curb Weight (lbs.) (1984)2266/(others)2293 2379
Ground Clearance (in.) 6.0 6.0
INTERIOR DIMENSIONS
Headroom (in., front/rear) 37.3/33.9
Legroom (in., front/rear) 43.2/26.1
Shoulder Room (in., front/rear) 54.5/51.9
Hiproom (in., front/rear) 49.7/47.6
Cargo Volume (cu. ft.) 9.1
CAPACITIES
Engine Oil with Filter (qt.) 3.5
Fuel (gal.) 15.8
Cooling System (qt.) 1.9
3rd Generation
Year '88-'90 '88-'91 '90-'91
Model 2.0 S 2.0 Si Si
ENGINE
Type Aluminum-alloy in-line 4
Displacement 1958 cc 2056 cc
Horsepower@rpm (SAE net) 105@5800 135@6200 140@5800
Torque (lb.ft.) 111@4000 127@4000 135@5000
Compression Ratio 9.1:1 9.0:1 9.4:1
Valve Train SOHC, 12-Valve DOHC, 16-Valve
Fuel Induction System Dual Sidedraft Constant Velocity PGM-FI
EPA Estimate (manual) 23/37 22/27 22/27
EPA Estimate (automatic) 21/27 20/26 20/26
DRIVE TRAIN
Automatic Transmission 4-Speed w/Sport-Shift
Final Drive Ratio (MT/AT) 4.27/4.13 4.27/4.36
Body Type Unit Body
Suspension 4-Wheel Upper Wishbone, Lower Control Arm
Stabilizer Bar (mm, front/rear) 25.4/17.0
Steering Wheel Turns, Lock-to-Lock 2.81
Turning Diameter, Curb-to-Curb (ft.) 34.8
Wheels 13-inch Steel Wheels w/Full Covers 14-inch Steel Wheels w/Full Covers
Tires 185/70 HR13 195/60 R14 85H
EXTERIOR DIMENSIONS
Wheelbase (in.) 101.0
Length (in.) 177.6
Width (in.) 67.3
Height (in.) 51.0
Track (in., front/rear) 58.3/57.9
Ground Clearance (in.) 5.7
Curb Weight (lbs., MT/AT) 2566/2606 2639/2674 2690/2725
Coefficient of Drag (Cd) .34
INTERIOR DIMENSIONS
Headroom (in., front/rear) 36.9/34.1
Legroom (in., front/rear) 43.1/27.1
Shoulder Room (in., front/rear) 53.1/51.1
Hiproom (in., front/rear) 51.5/45.1
Cargo Volume (cu. ft.) 11.0
Interior Volume (cu. ft.) 87
CAPACITIES
Engine Oil with Filter (qt.) 5.1
Fuel (gal.) 15.9
>Cooling System (qts., MT/AT) 6.3/5.6 6.7
4th Generation
Year '92-'96
Model S Si Si VTEC
ENGINE
Displacement 2156 cc 2259 cc 2157 cc
Horsepower@rpm (SAE net) 135@5200 160@5800 190@6800
Torque (lb.ft.) 142@4000 156@4500 158@5500
Compression Ratio 8.8:1 9.8:1 10.0:1
Valve Train SOHC, 16-Valve DOHC, 16-Valve DOHC, 16-Valve VTEC
Fuel Induction System PGM-FI
EPA Estimate (manual) 23/29 22/26 22/26
EPA Estimate (automatic) 23/28 22/27 N/A
DRIVE TRAIN
Automatic Transmission 4-Speed N/A
Final Drive Ratio (MT/AT) 4.06/4.29 4.27/4.43 4.27/NA
Body Type Unit Body
Stabilizer Bar (mm, front/rear) 25.4/23.0
Steering Wheel Turns, Lock-to-Lock 2.9
Turning Diameter, Curb-to-Curb (ft.) 35.9
Brakes 4-Wheel Power-Assisted Disc 4-Wheel Power-Assisted Disc w/ABS
Wheels 14-inch Steel Wheels w/Full Covers 15-inch Alloy Wheels
Tires 185/70 R14 87H 205/55 R15 87V
EXTERIOR DIMENSIONS
Wheelbase (in.) 100.4
Length (in.) 174.8
Width (in.) 69.5
Height (in.) 50.8
Track (in., front/rear) 60.0/59.6
Curb Weight (lbs., MT/AT) 2809/2862 2866/2921 2932/NA
Coefficient of Drag (Cd) .33
INTERIOR DIMENSIONS
Headroom (in., front/rear) 38.0/35.1
Legroom (in., front/rear) 44.2/28.1
Shoulder Room (in., front/rear) 54.0/50.6
Hiproom (in., front/rear) 52.2/41.4
Cargo Volume (cu. ft.) 7.9
Interior Volume (cu. ft.) 80.2
CAPACITIES
Engine Oil with Filter (qt.) 3.8 4.0 4.8/NA
Fuel (gal.) 15.9
Cooling System (qts., MT/AT) 1.78/1.75 1.85/1.83 1.95/NA
5th Generation
Year '97-'98 '99-'01 '97-'98 '99-'01
Model Base Base Type SH Type SH
ENGINE
Type Aluminum Alloy Inline 4
Displacement 2157 cc
Horsepower@rpm
(Automatic) 195@7000
(190) 200@7000
(195) 195@7000 200@7000
Torque (lb.ft.) 156@5250
Compression Ratio 10.0:1
Valve Train DOHC, 16-Valve VTEC
Ignition System Electronic, w/ Immobilizer
EPA Estimate (manual) 22/27
EPA Estimate (automatic) 21/27 N/A
DRIVE TRAIN
Type< /td> Front-Wheel Drive Front Wheel Drive w/ ATTS
Automatic Transmission 4-Speed w/Sequential Sport-Shift N/A
Final Drive Ratio (MT/AT) 4.266/4.785 4.266/NA
Body Type Unit Body
Stabilizer Bar (mm, front/rear) 25.4/23.0 24.2/23.0
Steering Wheel Turns, Lock-to-Lock 2.887 2.762
Turning Diameter, Curb-to-Curb (ft.) 36.1 37.4
Brakes 4-Wheel Power-Assisted Disc w/ ABS
Wheels 16-Inch Alloy
Tires 205/50 R16 87V
EXTERIOR DIMENSIONS
Wheelbase (in.) 101.8
Length (in.) 178.0
Width (in.) 69.0
Height (in.) 51.8
Ground Clearance (in.) ?? ?? ?? ??
Curb Weight (lbs., MT/AT) 2954/3009 3042/NA
INTERIOR DIMENSIONS
Headroom (in., front/rear) 37.9/35.3
Legroom (in., front/rear) 43.0/28.1
Shoulder Room (in., front/rear) 54.9/50.0
Hiproom (in., front/rear) 52.1/41.0
Cargo Volume (cu. ft.) 8.7
Interior Volume (cu. ft.) 78.4
CAPACITIES
Fuel (gal.) 15.9
Cooling System (qt., MT/AT) 1.725/1.70 1.70
